Toymods » Tech & Conversions » internals of the 3TGTEU
tanman
internals of the 3TGTEU Thu, 18 March 2004 06:10 Go to previous message
I have just been to my mechanic to get the verdict on my 3TGTE engine. The fault was found to be a broken ring land on no. 4 cylinder.(no surprise)
What I want to know is why no. 4 pison seems to be the first to go?
The rest of the engine is in good shape, the spec of the rebuild at this stage includes:
Ross 20 thou oversize forged pistons
porting of the cylinder head (standard valves)
ARP rod bolts and head studs
Custom T3 turbo on modified ported stock manifold
Custom inlet manifold using XF 65mm TB
RX7 S5 550cc intectors
The block, crankshaft and Rods seem to be strong in these engines. There are a few areas I am unsure about thought:
1) SUMP: is there a need for high volume sump?
2) Fuel Rail: any benefit to a custom rail?
3) Inlet manifold volume: I intend to keep the stock bottom half and construct a new top section with forward facing TB. By my calculations about 3.6 litres of voulume sounds right. Any thoughts?
[Updated on: Thu, 18 March 2004 06:11]
Read Message   internals of the 3TGTEU  tanmanThu, 18 March 2004 06:10
Read Message   Re: internals of the 3TGTEU 3T-GTEFri, 19 March 2004 01:03
Read Message   Re: internals of the 3TGTEU tanmanFri, 19 March 2004 03:06
Read Message   Re: internals of the 3TGTEU 3T-GTEFri, 19 March 2004 03:16
Read Message   Re: internals of the 3TGTEU 3T-GTEFri, 19 March 2004 03:46
Read Message   Re: internals of the 3TGTEU SRacinFri, 23 April 2004 02:20
Read Message   Re: internals of the 3TGTEU 3t-RA40Fri, 23 April 2004 03:07
Previous Topic:Raising Boost/Fuel/Ignition cut on 7M-GTE ????
Next Topic:What should i do??
Current Time: Sun Oct 25 15:47:11 UTC 2026
Total time taken to generate the page: 0.0040230751037598 seconds
